Pac SWI-PS
By garciarios · Nov 05, 2009in Problems/Troubleshooting💬 4 posts👁️ 3,396 views
Posted Nov 05, 2009 · 07:00 UTC#1
I am replacing my F90BT with the Z110BT.
I installed the F90BT myself so I am sure I can do the install. I am installing the MSN Direct, Ipod and the SWI-PS
with the PAC SWI-PS I am totally lost. Is there a tutorial to install it with pictures? I have a 2004 Cadillac CTS and I found this
http://www.pac-audio.com/swixprogrammin ... les&ID=150
My question is "Connecting the SWI-PS 's steering wheel control input wire to vehicle plug. " where is the Vehicle plug located?
Also is says "Connect pin #2 (purple in the 8-pin C3 harness) to accessory +12v"
Where is the C3 harness?
Last it says "THE ROTARY KNOB IS NOT PROGRAMABLE!" are they referring to the volume knob on the steering wheel? So how will I control the volume?
Any help will be appreciated Thanks.
Posted Nov 05, 2009 · 07:19 UTC#2
I did a self-install on my 09 Chevy conversion van recently... I had the same problem with the PAC SWIPS instructions regarding the harness. The installer that I bought it from had access to a website (http://www.directed.com/) that told me the location of the harness, but it had the wrong harness color listed. The PAC instructions are correct about the harness you need to interface.
I dont know about the rotary knob you are referring to, but if that is how you do the volume, then you might want to skip the SWIPS and consider a different wired remote that takes the place of the steeringwheel controls instead of attempting to interface with them via the SWIPS.
VBLUE42 mentioned a Sony product that looked cool in an earlier thread today... also Pioneer makes a marine-remote that has the core basic functions also.
Posted Nov 09, 2009 · 13:33 UTC#3
I too am having an issue with the PAC SWI-PSv1 (from Sonic)
I connected and follow the instructions. On my F150, the Volume and next/prev track do not work.
I also installed the Metra Axxess AFSI-02 kit to restore SYNC. So my Media/Phone buttons on the streeing wheel still work through sync.
Any help please?
Posted Nov 09, 2009 · 17:19 UTC#4
One thing I can tell you guys about the PAC modules is that they are very stubborn about how you connect the black ground wire. I had to run a wire straight to the negative terminal of the battery before I could get consistent function from the volume down button. Sometimes it would work and sometimes it wouldn't until I grounded it to the battery. Something you guys might want to try.
