need help with acronis
By clk320 · Nov 05, 2009in Hacks/Mods💬 7 posts👁️ 1,393 views
Posted Nov 05, 2009 · 23:11 UTC#1
Hi everyone just finished disabling the security feature of my hdd and i need to know if i have to use acronis in windows with my computer hd connected and what are the steps because i am confused between backing up and restoring the virgine imagine this is a new upgrade hd not the z1 can some one help cause i don't know how iam going to use acronis to upgrade my new hd to the z3 with maps thank you
Posted Nov 06, 2009 · 00:09 UTC#2
these are the steps iam doing iam choosing mount image from the acronis software then the z3 virgin image shows up then i choose to back it up and it shows me 4 partitions the ldata sdata msv and user 1 i then choose yes to back up and that's it but when i test new drive on z1 radio it gives me a msg can't use HDD can some one help pls
Posted Nov 06, 2009 · 08:15 UTC#3
You should be doing a restore, not a back up. Read the sticky posts above about how to do the upgrade.
Posted Nov 07, 2009 · 00:02 UTC#4
Hi everyone i purchased a new 60gig hd to convert my z1 to z3 i dowloaded the files and used BitLord torrent to download them. i have 13 tib files. i already disabled the security on the hd that was easy now i have been reading the step on how to use acronis i see it's not the same version as the 2010 but i am using the recovery wizard because i don't see a restore option when i pic the z3 virgin1.tib file it only gives me a file named z3 virgin13.tib i can't get that to change to virgin 1.tib like it says on the how to also when i continue and do all the steps that i read on the how to use acronis i get an error msg that says failed to create a scheduled task erro #1722 the rpc server is unavialable. can someone pls thank you
Posted Nov 07, 2009 · 01:30 UTC#5
Hay just about to give up with upgrading my z1 to z3 on a new hd drive that i bought just in case anyone out here in Miami has done this upgrade and can lend a helping hand thanks
Posted Nov 07, 2009 · 03:33 UTC#6
I am not familiar with the new version of Acronis. I would check their website for help. You just want to restore the TIB file (all 4 partitions) to your new drive. If you really get stuck and can not figure it out, you can send it to me to do the upgrade and tweaks.
Posted Nov 07, 2009 · 03:44 UTC#7
thanks i really appreciate it i would like to know were i can find the acronis version that is being used on the how to use and where can i download it from. also sending my drive how much would it cost me to get it programed by you thank you.
