2008 350z non bose
Yes! I have searched... No luck! I just installed my new z110bt and I couldn't get the mute wire out without hacking up the harness to much. So I used extra VSS wire to attempt the video bypass. So my problem is the volume controls and the rear speakers aren't working. Yes! I pulled it out and check all the connections. I was using a guide on a 350z forum do my install and they had 3 grounds one was the green parking break(check) and the Black ground(check) and I did the by pass so I had a third on the same as the parking brake ground.(check) so I am wondering if that third ground could be throwIng the ATT? I have tried the turning off the AV and going to setting and turning off the mute, still no luck! Should un ground the 3rd ground? I am hoping you guys can help me before I decide to take it to a stereo place to fix it.
Thanks Marcus
