Droid
By blindmind3 · Nov 06, 2009in General💬 12 posts👁️ 2,798 views
Posted Nov 06, 2009 · 20:58 UTC#1
In case anyone was wondering, the Droid works fine with the F90BT. Contacts sync'd first try no problem.
Posted Nov 06, 2009 · 21:17 UTC#2
Good news, since that's going to be my next phone in a week
Posted Nov 07, 2009 · 15:25 UTC#3
How is the voice dialing?
Posted Jan 13, 2010 · 20:03 UTC#4
Did you have to do anything special to get your contacts synced with droid? I have it synced up via BT but for some reason the contacts dont want to sync?? I have the newest droid update.
Posted Jan 15, 2010 · 00:31 UTC#5
for scarz i had the same problem when i got the droid back in november. a couple of things i did that seem to have worked for me: i cleared the memory on the avic unit from the main phone menu (of the avic unit and not the phone) then re-synced. when syncing the first time the droid had a confirmation message in the notification pull-down just like when mounting it as a usb device on a pc, you have to go there and confirm the connection. i don't remember seeing that message on the droid again since the first time.
editing to add that i have a 700bt, not the same unit as the OP. but the concept should be the same.
Posted Feb 05, 2010 · 11:25 UTC#6
What other BT features are available with the droid and the F series such as SMS alert, etc..
Posted Feb 07, 2010 · 21:40 UTC#7
None. Just the same as any other regular phone unfortunately. F-Series fails.
Posted May 22, 2010 · 23:25 UTC#8
I love my Moment w/ 2.1 on it. Now if I can find a way to get my F90BT to be able to stream music over BT from my phone so I could get rid of these cords.
Posted May 22, 2010 · 23:30 UTC#9
Search the general forum for a solution.
Posted Jul 01, 2010 · 02:40 UTC#10
I've tried reading the general forums, but I'm clearly not using the right keywords when I search. I've got wifi and everything on my Moment, so figuring out how to make the stereo be able to connect to my phone so I could stream music would get rid of this cord I've got to use all the time.
Posted Jul 01, 2010 · 03:12 UTC#11
Just click the sub category and start reading the threads. An example would be to click the General forum and start reading the threads from the top.
Posted Jul 01, 2010 · 04:49 UTC#12
I posted updated on the a2dp workaround thread after I searched on ebay for "a2dp receiver" and have yet to get an update for anything other than using a $20 unit that doesn't even sound as good as a dual male headphone cable. If I'm going to stream BT to my deck, I'd like to do it as cheaply as possible ($2 vs $20) if they're all going to have the same sound in the end.
