Map Info Button changes
By Bluesbroeder · Nov 07, 2009in Hacks/Mods💬 2 posts👁️ 799 views
Posted Nov 07, 2009 · 11:07 UTC#1
Can someone help me with the following problem.
I like to change the position of the Map Info Button during navigation.
I found the lines below in the navigatemap_800_480.ui, but when I change the position ( X and Y) or the visibility (visiblemode) it looks that there is running another process because this button is not changing. What do i need to change more?
;Map Info Screen Button
Posted Nov 07, 2009 · 21:35 UTC#2
You need to search all other files for references to those particular buttons. I think one file will be navigatemap.ui (in common directory) but I'm sure they're in a couple of other files too.
