problems booting with Testmode F700
By dewitteman · Nov 08, 2009in Hacks/Mods💬 6 posts👁️ 1,098 views
Posted Nov 08, 2009 · 11:56 UTC#1
I have tried to boot with testmode, the one with the mitcap files.
It didn`t work and the problem I now have is that the device doesn`t boot with the sd card, I have tried several sd cards.
The question I have is:
who can give me an direct link to a working testmode file, And how big should the card be
who can give me an advice in the following mather, first upgrade to version 3 and or thirst upgrade eazirider for the latest IGO maps and program
Posted Nov 08, 2009 · 15:23 UTC#2
This has been covered many times on here. All of the answers to your questions have been answered already. Do a search and I guarantee you will find all of the answers.
Don't forget to backup first.
Posted Nov 08, 2009 · 17:02 UTC#3
Hi. Format your SD card using Start->Run and type CMD (enter)
Now type format (driveletter:) /fs:fat32. The drive letter is the drive letter your SD card has.
Example if you can enter the SD card using g: then type: format g: /fs:fat32
Now copy the Testmode.zip onto your SD card and try again.
I did format my SD card using windows and checking that it was set to FAt32, but it didn't work untill this.
Posted Nov 08, 2009 · 17:25 UTC#4
I already formatted the card as you descriped.
Problem is that the Testmode files I find here in the forum are corrupt. When I extract I get aan error. please give me a link to aa working file.
My firmware is 2.007.
Just to be clear, when I boot with the card, nothing happens, should I pres any other keys?
Posted Nov 08, 2009 · 20:43 UTC#5
viewtopic.php?f=34&t=28717
The testmode file I posted here works.
Posted Nov 09, 2009 · 18:33 UTC#6
Thanks, it works.
now I am trying to do the parking break bypass bij adusting the pioneer.ini file.
this by changing the value from 16 to 128.
this doesn`t work.
does anybody have a solution?
