All:
What is the entire list of changes -- especially install harness/wiring changes -- to move from a D3 (with the BTB200 and older XM tuner) to an X710BT?
Here's what I know so far:
- KEEP Old XM tuner (GEX-P10XMT...will work w/IP bus, just won't get NavTraffic)
- KEEP old GPS antenna
- KEEP old microphone
- KEEP old AM/FM antenna adapter (or upgrade to better one ...)
- REMOVE BTB200 (Won't need it for Bluetooth anymore)
- REMOVE old iPod cable and buy the new one for the F/X series
Unknowns:
- Will Soundgate CANPULSE4 & CAN-PIO harness (speed signal and steering wheel controls) still work with X710BT?
- Do I have to re-wire anything in the RCA harness (don't think I'm using it...no camera, using iPod cable)?
- Do I have to re-wire anything in the power cord/speaker connector or harness?
- Do I have to re-wire anything for the bypass (D3 install was apparently bypassed)
- Will the Metra fit-kit/fascia for the D3 fit the X710BT?
- Is there a seperate install kit for the X710BT that's different from the D3's (the "Pioneer ADTVA133 Double Din Installation Kit")?
Any advice on how hard it will be to upgrade an install from from a D3 to a X701BT would be most appreciated!
- JohnnyD
