I lost the GPS and Blue Tooth audio after upgrading to the "NON-Official 3.0 firmware". Is this an easy fix? I have the F90BT. Thanks.
Posted Nov 19, 2009 · 13:37 UTC#1
I also have this problem (f700). Haven't figured it out yet, but the GPS is not locating any satelites.
Edit: Solved
I solved the problem I had. The SDcard I was using for the update was corrupt/faulty.
I switched to a new one and redid the update from scratch, worked perfectly. Maybe try messing around with a different card and redoing the update will solve your problem too?
