AVIC-Z1 Problem?
By rscocca · Nov 26, 2006in Problems/Troubleshooting💬 4 posts👁️ 1,282 views
Posted Nov 26, 2006 · 18:52 UTC#1
:evil: while driving to Florida from NY my newly installed Avic-z1 kept rebooting. i installed the system myself (18 Years as an auto electronics installer) i have double checked and isolated all connections, all OK. is this problem a programming or hardware problem? Version 1.00 software on a unit made after June of 06.
HELLLP
Posted Nov 28, 2006 · 00:15 UTC#2
Year/make/model of the vehicle. When you say it reboots, you mean it's totally shutting down?
Posted Nov 28, 2006 · 16:26 UTC#3
Year 2003
Make Chevy Conversion van
Model 1500 AWD
Yes it totally shuts down then reboots as if key was turned off then on again. i have the chime relay installed so everything works as if it where a factory radio. had a Avic N2 installed before with out any problem till the screen crapped out.
Posted Nov 29, 2006 · 04:26 UTC#4
I'd look into the datbus interface being suspect. Try running an accy wire from the ignition. If it stops randomly rebooting then oyu know it's the interface causing the problem.
