This is the review I spoke about....
- no support for cd changers but many feel that because of usb drives and ipods, changers are legacy...whatever!
- touch screen has a sweet spot that is small and off-center so it's easy to make the wrong selection and have to waste time on a redo...
- no IR functionality which means wireless remotes cannot be used and this unit really needs one...
- xm works great BUT xm traffic is not supported, only msn direct...
- no exterior mute button....
- installing the hd radio module disables regular am/fm functionality...
- route guidance has no introductory statement to start your route, you just start driving and eventually it begins giving directions...
- route guidance audio does not identify by exit number, street or exit name, just take next and you must look at screen for what next is...
- last unit i had gave me my vehicle speed as well as the current posted speed limit, this unit gives neither...
- adding a route is real work. to start a route you must type each and every complete word exactly, it does not help you complete words with suggested common choices nor is it flexible when searching...
- when recalculating a route, it says nothing and starts the process very slowly
- there is a search by address voice function, but it's slow and awkward, using it is a real struggle...
- no voice commands for basics such as "go home", "cancel route", etc. so you must touch screen through several menu layers for them...
POI TRULY SUCKS...
- POI appears to first search alphabetically and then by proximity instead of the other way around or some other strange way, i'm really not sure what it's doing but i am sure it needs to be doing something different...???
example: when i select POI> ATM> it gives me pages and pages of Bank of America locations beginning with the closest at say .02 miles and one after another extending out to about 40 miles until it reaches some internal limit. i can be parked in a Washington Mutual parking lot staring directly at their building from 50 feet away and this unit's POI> Banks> will not find it and all of the other POI menu choices seem to follow this same goofy search method. the only way i have found to locate a POI (other than Bank of America) is to type it or use the voice command "find the nearest" and even then the results are questionable at best. for example it comes back with nothing when asking for nearest in-and-out burger or 7/11 store, go figure...??? another example would be i ask it for the nearest kragen auto parts store when i was +/- 100 feet from a location that had been there at least 15 years and this unit did not list it and gave me one 4.5 miles away as being the nearest to my present position..???
actually the POI function on my wife's $130 portable navigation unit works much, much better than this one...
