Suddenly bluetooth stops synching?
By Blind · Nov 20, 2009in Problems/Troubleshooting💬 11 posts👁️ 1,634 views
Posted Nov 20, 2009 · 21:11 UTC#1
I have an F700BT, and a Palm 800w phone.
Worked fine ever since I got the F700 right when it was released, worked fine after I updated to 2.0.
Last week, the blue led was off, and my phone didn't sync, it took me about an hour of turning the bluetooth off/on to get it to even see my phone, deleted the old pairing, re-paired it, worked for the rest of that drive, then again now it doesn't sync and the blue light stays off.
Any thoughts?
Posted Nov 25, 2009 · 21:25 UTC#2
Mine has started doing the same thing. started a couple of weeks ago, I thought it might be software related so I upgraded to version 3.0. Upgrade arrived today, installed it and still no luck. I went into the setup menu (reset, eject, menu, map) then the unlock code. Under there I went into the bluetooth menu and got an error "cable unplugged" when I selected the option for Bluetooth MAC. I assume this is an internal hardware issue, but I was hoping there might an easy fix?
Can anyone help? Likewise were you able to get yours working again?
Thanks in advance for any help
Posted Nov 25, 2009 · 21:31 UTC#3
I've had no luck, keep this updated if you find anything.
Posted Dec 01, 2009 · 01:06 UTC#4
on a related note, I just added an f700bt to my 'new to me' truck, and my phone sync's with it perfectly and it syncs up just like normal with no intervention. So the issue is not my phone, seems like something on that f700 has died :(
Posted Jan 13, 2010 · 03:31 UTC#5
Ok mine was able to sync today and so far appears to be working again.
The only thing I did differently, was to select the "pair from mobile phone" option first when in the "add device" menu. Good luck to all and hope this works for you as well!!!! :D
Posted Feb 01, 2010 · 16:26 UTC#6
Hi, i have the same problem, mi bluetooth died some days before. Mi bt conection is not blue any more. I tried to pair it from the cell phone, also reset the unit, and nothing...
Please help me.
Posted Feb 01, 2010 · 16:26 UTC#7
Please help me.
Posted Feb 10, 2010 · 02:09 UTC#8
I can make mine work pretty consistently now.
Basically if I turn the car on and it isn't working, if I go to the phone settings, then check the bluetooth software version, it displays "not found" rather than the version #.
If I then turn bluetooth off/on 4 times, the software version will show correct (...SW330 RC3...), and the phone will sync up and work for the duration of the unit remaining on.
Posted Feb 11, 2010 · 17:07 UTC#9
I too have recently had this problem. IMO there are far too many people 'suddenly' having the exact same problem for this to be merely a coincidence.
This reminds me of the time-aware camera bug the Motorola Droid phones had when they were first released. I think Pioneer needs to be pointed to this thread so more awareness can be raised of the scope of this problem.
Posted Feb 11, 2010 · 20:03 UTC#10
Have a look in flashdisc/user/userdata/igo/save and see if there any files that start with msn.If there are delete them then try your BT again.Apparantly msn kills bluetooth!I got this info from a fellow forum member and it solved my BT problems!
Posted Mar 21, 2010 · 20:43 UTC#11
i fixed this problem on my f90bt with official 3.0 installed by updating the bluetooth with the PRIMARY version found on pioneers's website. hell this even makes the phone ring whereas before the music would go silent but there wouldnt be a ring.so if your bluetooth stops syncing, can't connect or find your phone, or if you dont hear a ring when receiving a call, download the 3 files from pioneer, put them on an sd card, unplug your ipod or usb device, update the bluetooth files and your set
