F900BT Vs F10BT
By rad2085 · Nov 21, 2009in Hacks/Mods💬 5 posts👁️ 1,228 views
Posted Nov 21, 2009 · 21:24 UTC#1
Hi All
I'm new to this pioneer navigation systems. Here in Australia we currently have the option to buy the new F10BT or the slightly older F900BT.
I was wondering if the test mode mod can be utilized on the newer F10BT, as i wish to run ozi explorer on the system, this program is a navigation program that uses topographic maps. The program is available in a windows CE operating system.
Has anybody been able to access the operating system of the new F10BT, or should i stick to the earlier model which has plenty of mods/info available.
Many thanks in advance
greg
Posted Nov 22, 2009 · 00:19 UTC#2
I believe that the F10BT is the equivelant of the Z110BT. If it is, then it uses a different OS and you cannot use testmode on it
Posted Nov 22, 2009 · 00:36 UTC#3
The answer is certainly no. The F10 is the same unit as the Z110BT and has nothing to do with the previous F series. And as stated above, it does run Windows CE and will not run Testmode so there will be no hacks or mods for this unit.
Posted Nov 22, 2009 · 00:58 UTC#4
. And as stated above, it does run Windows CE and will not run Testmode .
Lol, I think that was a typo meaning that it does 'not run windows CE'. If the Z110 was cabable of being modded, I would have one.
Posted Nov 22, 2009 · 03:47 UTC#5
Yea my mistake. It does NOT run Windows CE.
