How to Put DVD and Video on Sansa Fuze
By hotcoffee893 · Nov 26, 2009in General💬 1 posts👁️ 456 views
Posted Nov 26, 2009 · 00:23 UTC#1
The Sansa Fuze is a portable media player developed by SanDisk, and released on March 8, 2008. The Fuze is available in three different Flash memory capacities: 2 GB, 4 GB, and 8 GB. Storage is expandable via a microSDHC slot. It has a 1.9 inch TFT LCD display with a resolution of 220 by 176 pixels. The Fuze supports MP3, WAV, WMA audio file, and can display both pictures and videos, AVI, MPEG4, WMV, QuickTime, MPEG2, ASF can be played on it and you can also watch picture of BMP, JPEG, TIFF, GIF on it.
A lot of people choose sansa as their company to kill time when they are free.
Some people know how to put videos on it, some not. In the following text, I will show everyone who has a sansa and want to enjoy videos on their players.
(Not only Sansa Fuze, but also other Sansa player that can play video)
I divide this article into two parts:
1. How to put dvd on sansa
2. How to put video on sansa
To complete this process, I need a tool called 4Videosoft DVD to Sansa Suite
Part 1: How to put dvd on sansa with DVD to Sansa Converter
Step 0: Download and install 4Videosoft DVD to Sansa Converter
Step 1: Import DVD.
Place the DVD into your DVD drive and click the “Load DVD” button to load DVD.
Step 2: Video settings.
Select the output video format you want from the “Profile” drop-down list.
Step 3: Place video
Click “Open Folder” button to open your output destination file.
Step 4: Start conversion
Click the “Start” button to start your conversion and in a short while it will be finished.
Part 2: How to put video on sansa with Sansa Video Converter
Step 0: Download and install 4Videosoft Sansa Video Converter
When you finished the download process, run the .exe file to install it.
Step 1: Click “Add files” button to import videos.
Step 2: Extend the "Profile" category to select an output format.
Step 3: Click “Open Folder” button to open your output destination file.
Step 4: Click the “Start” to convert.
Tips----- Basic functions for all the 4videosoft:
1. How to change your video effect
If you want to adjust the effect of your movie, please click the “Effect” button and a pop-up effect window will appear. It allows you to edit your movie’s effect including “Brightness, Contrast, Saturation and Volume”.
2: How to crop off the black edges and adjust the size of video play region
By using the "Crop" function you can crop off the black edge of your video and you can also drag the line around the video image to adjust the video play region to fit for your mobile devices
3: How to split your video
The "Trim" function also servers as a video splitter for you to get any time-length video episode. You can set the "Start Time" and "End Time" to set the exact time-length of the clip or you can directly drag the slide bar to the position you want.
4: How to join the videos
If you would like to put several files into one output file, please tick the check box of the “Merge into one file”.
5: How to save your favorite picture
If you like the current image when preview video, you can use the "Snapshot" option. Just click the "Snapshot" button, the image will be saved and you can click the "Open" button next to "Snapshot" button to open your picture. :D
