My 910bt does not show the street names on the map. I have went into the settings and activated it but still nothing. It tells me at the bottom left what street i am driving on but on the map page no names. Has anyone else experianced this? any ideas?
x910bt not showing street names ?
I had the same problem so I changed it to 2d instead of 3d and they showed up.
It shows them in 2d but not 3 d is this normal?
it does show them in 3D but you have to be zoomed in to about 500ft or 300ft before they show up. i can only imaging that this is a mistake but who knows if it will ever be changed,
I have the same issue on my X910BT. The street names do not show in 3D unless I change the map scale to 500 or 300. But my question is: after changing the map scale to 500 or 300, and later on, turning the map off, then turning it on again, the scale is back at 1000 with no street names, making it necessary for me to lower the map scale to 500 or 300 again. This happens everytime - the map scale defaults back to 1000. Is there a way to "save" my map scale change?? By the way, I have an X710 BT in my other car and it does not have this "no street name/map scale" issue. It works fine all the time.
You can set the default zoom level in the settings.
I changed to 2D and they work. Not as cool looking, but functional.
you want to go into navi settings and turn "SMART ZOOM" off. this will stop it from defaulting back to 1000ft
Hello, Newman: followed your suggestion and BINGO! Once the level was lowered to 500 and the smart zoom was turned off, the street names in the 3D mode are now staying on screen. Thansk for your help.
Is there a way to change the default zoom while keep the smart zoom function?
I think the smart zoom helps you to zoom in when the car slows down to intersections and zoom out when one is driving a long straight road.
If you go into the same settings menu i mentioned above and have smartzoon ON there should be a little wrench icon next to it. click the wrench icon to enter the smartzoom settings. you are able to adjust how far it zooms out. i have not played around with this myself but it should allow you to do what you're asking.
