Pics of iPhone mounts
By MLTTASK · Nov 29, 2009in General💬 10 posts👁️ 2,652 views
Posted Nov 29, 2009 · 20:26 UTC#1
I'm trying to find a nice mount for my iPhone to go with my new Z110BT. If you'd post pics of your solutions I'd love to see them. I'm looking for something I hopefully don't have to drill holes in my car to mount. Thanks!
Posted Nov 29, 2009 · 21:59 UTC#2
Go to www.proclipusa.com They are not cheap but the quality is rock solid. I have owned about four of these mounts across several vehicles and devices and they are the best I have found. I will post a pic of the one I currently use in my car when I get back into town later tonight.
Posted Nov 30, 2009 · 00:09 UTC#3
Thanks for the tip and the upcoming pic.
Posted Nov 30, 2009 · 07:57 UTC#4
This is the one I use. It is a two part solution. There is a vehicle specific mount and the device holder of your choice. This solution runs 100+ so it is not for everyone. I however find it rock solid and don't mind paying good money for a good solution.
Below are the photos that I took of the cradle installed. The cable plugged into the built in dock connector on the cradle is the Apple Composite AV cable. It is plugged into the AV2 input on the back of the Z110BT. This gives me full AV capabilities from the iPhone. The USB portion of the cable is plugged into a USB/cigarette lighter adapter in the center console which gives me charging of the iPhone.
Posted Dec 02, 2009 · 05:39 UTC#5
That's the same I just ordered. Thanks for the installed pics.
Posted Dec 02, 2009 · 05:49 UTC#6
Awesome, I think you will like it. That cradle also will allow you to mount the phone with any case around the phone.
Posted Dec 06, 2010 · 22:39 UTC#7
where can I by this from. I like the solution. Thanks.
Posted Dec 06, 2010 · 22:45 UTC#8
proclipusa
Edited Dec 07, 2010 by VBLUE42
Posted Dec 09, 2010 · 05:25 UTC#9
I ended up getting the Proclip quite a while ago and secured it to the dash with 3M command strips. Nice and clean look.
Posted Mar 04, 2011 · 16:34 UTC#10
Check out the 2point5 spec docks. They're expensive but look as oem as it gets. www.2point5.com
