Mod Help
By scotty3x3 · Nov 30, 2009in Hacks/Mods💬 7 posts👁️ 955 views
Posted Nov 30, 2009 · 04:21 UTC#1
Hey guys. I'm running Diaftias mod on my F700 and it's working flawlessly. I would like to know how to add the sky to my 3d view an the tilt that will follow me with the sky mod at the same time. Any help is appreciated!
Posted Nov 30, 2009 · 22:57 UTC#2
You can try this viewtopic.php?f=34&t=26446&start=855
You will have to get dpdurst's schemes from his thread.
Posted Dec 01, 2009 · 00:16 UTC#3
The sky is already in there. If you want to make sure its always displayed turn off smartzoom. It will lock into where you tilt it.
This is a screenshot from my second post in the thread. Are you seeing something different?
file.php?id=8381&t=1
Posted Dec 01, 2009 · 03:19 UTC#4
Ok. I haven't turned off smart zoom... I will try that now. But as of right now, when I tilt the 3d display, I just see a solid blue at the top and the system doesn't follow behind me, it just stays where it was until eventually the arrow (my car) is just gone off the screen from driving too far away. Is it not possible to have the system follow me while the screen is tilted so I can drive with the sky at the same time?
Posted Dec 01, 2009 · 05:00 UTC#5
You need different schemes. Read my post above. If your arrow drives off the screen, tap the map button.
Posted Dec 02, 2009 · 14:26 UTC#6
Ok... so I turned the auto zoom feature off and now the system will "follow" behind me in 3d mode while tilted but I still do not have the clouds... just a big blue area where the clouds should be.
Posted Dec 02, 2009 · 23:40 UTC#7
You have to install different schemes like I said before. Clouds don't usually show up on their own. You have to put them there. Read the other threads on how to put new schemes on. Dpdurst has a lot of schemes, Follow the link I gave you earlier.
