Ipod and USB together
By urtruelove78 · Dec 02, 2009in Problems/Troubleshooting💬 24 posts👁️ 2,753 views
Posted Dec 02, 2009 · 20:43 UTC#1
Hello all,
I have gone through all topics and i know that USB hub is not supported when using both ipod and USB flash drive.
But my question is can i use USB hub and use ipod OR Flash drive one at a time. That way i will have both connection and can use only one at a time based on my need.
Posted Dec 02, 2009 · 21:38 UTC#2
It states in the owners manual that USB hubs are not supported.
Posted Dec 14, 2009 · 04:42 UTC#3
hmmm...
So the IPod integration (CD-IU50V) hogs the sole USB port? With no support for a hub?
If so, I would assume that my best option would be to run a USB extension and a 3.5mm extension, to say, my center console(where I currently store my Ipod) and flush mount the female ends to the inside of the console??? Then I could unplug the IPod USB and still be able to hook up a thumb drive?
I thought I read somewhere that the CD-IU50V is 5' long?
Posted Dec 23, 2009 · 05:45 UTC#4
Well cheers people. I tested usb hub that was lying around to see if it works.
It did but only in certain way. If you USB drive connected and you connect iphone, it does not work. But i connected Iphone first and then connected Usb drive and both show as active and i was able to play both of them after one another. My usb hub was usb 1.1 so i'm gonna run and get usb 2.0 so that it does not effect the performance of either one of them.
VB please make sure you have tested things before you go advising people.
Posted Dec 23, 2009 · 06:39 UTC#5
Maybe you should go back and read what I wrote noob.
Posted Dec 23, 2009 · 06:52 UTC#6
Below are two such post where you posted wrong and inaccurate info. So check yourself next time NOOB!!!
Both version looks different as well. 1.68 is Blue housing, while 1.67 was black housing.
WRONG!!!
I just finished installing Z110 with pac swi-ps in 2007 hyundai santa fe and programmed my mute button on steering to VR. For that you have to have swi-ps version 1.6.7 onwards which supports answer call, end call, phone status and VR.
WRONG!!!
Posted Dec 23, 2009 · 07:21 UTC#7
Heres number three!!!
No need to buy separate cable. I used iphone charging cable with 3.5 jack cable that i bought from frys for $0.99.
:roll:
It works perfectly and i can use usb drive when and where i need it, if you buy that cable then you are stuck with using ipod/iphone and no usb drives.
WRONG!!! This will not support video on any current ipods or iphones.
Posted Dec 23, 2009 · 21:27 UTC#8
WRONG!!!
Nope. Can't believe what you say anymore.
Show me a 1.6.7 with blue housing and i believe you.
WRONG!!!
please read it carefully, i said 1.6.7 onwards not 1.6.7.
for your reference to understands what onwards is
http://dictionary.reference.com/browse/onwards
Posted Dec 23, 2009 · 22:09 UTC#9
I have one right now. Go to the site and read the technical specs. You don't have to believe me. Your the noob and I am not.
Posted Dec 23, 2009 · 22:27 UTC#10
PAC SWIPS version 1.6.7 are blue...
And as for the USB hub... although they say that it's not supported, doesn't necessarily mean that it won't work, or at least half way work... Just means that Pioneer will not guarantee or support it. There is probably too many different hubs and standards for them to justify the cost of Customer support and development for it.
Posted Dec 23, 2009 · 22:49 UTC#11
Clearly, that is why I responded to the OP that it stated in the manual that it was not supported. I did not know for sure so I did not say for sure.
Posted Dec 24, 2009 · 01:57 UTC#12
Ahead of you there... just putting it out there in case "noob" didn't quite understand your post...BTW, I'm a 110BT Noob as well :oops:
Seriously though... I just flipped through Pioneer's PDF on their site.... It actually says "cannot be used with a USB hub"... In which case, I'd be careful as to how much current you pull through that hub...even if you got it to half ass work...
It would have been alot better had they included two USB ports so that you could have the best of both worlds...
Honestly, I wouldn't mind an updated IPOD IP-Bus adapter for this unit, if possible...
Posted Dec 24, 2009 · 02:09 UTC#13
I wouldn't be surprised if the next unit has at least two USB inputs but I wouldn't ever expect to see any stated hub support. And as far as you being a noob, you havnt made a complete ass of yourself like the other one has so your good. :twisted:
Posted Dec 24, 2009 · 11:40 UTC#14
I And as far as you being a noob, you havnt made a complete ass of yourself like the other one has so your good. :twisted:
It doesn't matter to me how much you want to say 'noob' but this 'noob' just proved you wrong on one occasion and you are not ready to accept that.
As far as i confusing people, i do accept that i made some posts in hurry without testing it but in future will make sure that i have tested things first unlike you who won't accept it.
Posted Dec 24, 2009 · 11:43 UTC#15
That one looks like what i have and its 1.6.8
Posted Dec 24, 2009 · 11:55 UTC#16
Man you really don't get it do you. You clearly are not starting off very good on this forum. And you are looking more stupid every time you post a response. You were out of line by coming after me and you stuck your foot down your throat by committing the very same behavior that you accused me of that I didn't do. I pointed out your idiocy and any body reading these forums can clearly see that. Do you really think your fooling any body or are you really that stupid.
Posted Dec 24, 2009 · 11:58 UTC#17
Ok smart guy, heres where I make you look stupid again. Please quote the thread where you have proved me wrong in this little exchange we have had going here. Once you do that I will then quote the thread that makes you look really stupid.
Posted Dec 24, 2009 · 18:14 UTC#18
They look identical... the only thing that separates them, is the version number... and of course, the addition of VR
Posted Dec 25, 2009 · 04:12 UTC#19
I think in this same thread you said USB hubs won't work because manual says so. Isn't it :?:
Posted Dec 25, 2009 · 04:17 UTC#20
Please quote the thread where I said it wouldn't work.
Posted Dec 25, 2009 · 04:33 UTC#21
Who said this??
Posted Dec 25, 2009 · 05:04 UTC#22
I did. And no where did I say it wouldn't work as you claim in the comment above. You see, this is what started this whole thing. You clearly cant read something for what it says without misinterpreting what it says. You clearly misinterpreted what I wrote and then called me out to say I should test before I advise others. Well I have never posted any info without knowing what I am talking about as my history on this forum will show. The worst part about this whole thing, is you are guilty of what you have accused me of which I have clearly pointed out here. You clearly are not capable of understanding that one thing you don't do, when you go to a forum as a new member, is call out senior members out of line. You have done that here and it stops now. Check your PM.
Posted Dec 26, 2009 · 01:22 UTC#23
I tell you what WOULD be beneficial out of this...
Would be that you post exactly what hub you're using.... Even though Pioneer states that they don't support it, it would be nice to know which one's have possibilities of working worth a poo...versus which ones that don't...
There are far too many different USB standards/hubs/manufacturers, to go play "trial and error" with....
Posted Dec 26, 2009 · 02:04 UTC#24
Good idea, lets get back on track. Also, please elaborate on what interface control you get with the hub attached for the various media players that work with the hub.
