just installed my z110bt on my g35
By jjakes24 · Dec 05, 2009in General💬 3 posts👁️ 1,078 views
Posted Dec 05, 2009 · 15:22 UTC#1
All I can say is wow, this thing was well worth the money since I got the deal from 6th ave from amazon. Everything is real responsive, bluetooth works great, boot-up is real fast, navigation works real well. Even the steering wheel controls are great (slight millisecond delay but I can live with that). The only problem I had was getting that damn bypass to work. Changing that wire might of been one of the hardest things I had to do without blowing a gasket and screwing the thing up. Even after the wire switch and verifying my grounds, I was still not getting a good connection a the harness. FInally, I knew I had little space behind it so I just shoved it back and the parking brake warning went off and the bypass works like a charm. My brother has a new lexus and I have to say this may be better than his factory system (not counting the parking assist).
Posted Dec 05, 2009 · 18:50 UTC#2
i have the bose 10.1 in my car with the 110 and the new headunit blows the stock one out of the water lol. Best part is 10.1 is still 100% functional The bypass is the easiest. The hardest part was making the custom connector so i wouldnt have to bypass my amp. Had to use the low outs on the pioneer and create a car adapter which encorporated rca's so i wouldnt blow speakers or the amp
Posted Dec 18, 2009 · 18:22 UTC#3
So did both of you guys only replace the Bose headunit with the z110bt and run from the pre-amps?
Mine is supposed to arrive on Monday and I plan on keeping the rest of my system stock for a while.
jake, what year is your G35?
