F900 will not get past the boot up screen
By wedebrook · Dec 05, 2009in Problems/Troubleshooting💬 8 posts👁️ 1,197 views
Posted Dec 05, 2009 · 22:24 UTC#1
When I turn my unit on, I get Pioneer boot screen, and then the unit turns off. I upgraded to the official 3.0 from Pioneer a few months ago, if that makes any difference. I used one of the newer versions of testmode from this site to go in and take a look around at the files, and it seems my flash file is pretty much empty. There were like 4 files left in there, and absolutely 0 folders. No iGo, no nothing. Anyone know how to fix this? Are there just some files on one of the SD cards from the 3.0 update from Pioneer that I can copy to the flashdisk?
Posted Dec 06, 2009 · 00:57 UTC#2
Just to add to this, when I inserted the 1st 3.0 SD card, in an attempt to reflash it, it went through the file copying process, rebooted, then froze at the Pioneer boot screen. I inserted SD card #2, but no dice. If I press menu while it is stuck there, I can access the menu, but none of the menu functions work. The only thing that I can truly access are the settings, and that doesn't really help me at all.
Posted Dec 06, 2009 · 01:28 UTC#3
Having the same issue as you mate, ive resolved to removing the unit from my car until i can fix it, ive tried restoring my 2.00900 backup, but still get stuck on pioneer boot logo, press menu brings up an utterly useless menu, ive tried all sorts of things so far but nothing, ill keep you posted if i find anything that works.
Posted Dec 06, 2009 · 04:09 UTC#4
Right on. I was certain I wasn't the only one.
Posted Dec 06, 2009 · 08:11 UTC#5
im gonna put it down to either of the two things i was doing at the time:
I loaded a corrupt backup as av.exe just crashes, or more likely, im using the wrong windows CE images. might try find some other images and give thema whirl. ive go tthe unit connected to a breadboard and power supply, so i dont have to race out to the car to try things.
Posted Dec 06, 2009 · 16:11 UTC#7
Well, since mine is still installed in the car and we're looking at about 30*F, let me know if that works out for you, and I'll give it a shot.
Posted Dec 07, 2009 · 18:34 UTC#8
All is now well with my F900. I followed this procedure:
http://avic411.com/wiki/index.php/Compl ... tall_Guide
And reloaded everything completely. I have gone through 4 driving cycles since fixing it, and it is holding up well so far. If it dies again, I will be sure to come back to this thread and post.
