Can any help me out witht he names for some images for making a skin. i will be looking for the other tab's also that go at the bottom of the system settings & phones screens to. Thanks to anyone who can help me out with this.
What you are requesting is not an easy task. The images that you are looking for are in the COMMON folder and there are 26 buttons with 3 images each..... inactive, NORMAL, and Push images for each button. The images that you are looking for are ranged between 746_32K_MN-550 to 746_32K_MN-574. To determine EXACTLY what each button does to a 'T' , you have to make a copy of a dummy image .res file and extract it. Select the images that you want and open them up in Photoshop and number each image using the 'NORMAL' one of each file. Turn it back to image.res, load it into your avic and then the numbers of each image should be displayed on your AVIC with their exact location. It is a little bit of work, but it will give you exact locations of all images. Have fun!
