I have an Avic-z2 w/surius worked great for a year now. Today got in truck to go to work and no Surius, screen says "No Device"? Any one help? Thanks!
Surius radio problem
That is a really sirius problem!
Sorry, but I could not help myself ![]()
Have you checked the power to your Sirius box?
And garret, this is no time for jokes. We need to be Sirius here. ![]()
Siriusly, also check the fuse on the yellow power wire going to the Sirius box.
You better do it. I've seen Garret when he gets Sirius and Siriusly.... it's not pretty.
This will siriusly need to be moved to the 'off topic' forum.
Rob,
Were you able to verify power/fuse to the sat radio unit?
I had a similar issue. Checked to see if the fuse was blown, it was good. To get it working again I disconnected the power supply from the back of the sirius unit and plugged it back in again. Started the radio and it was back This happened after I had to replace a bad battery in my Charger.
Rob,
