Cruise Dial Images
By dragon24 · Dec 11, 2009in Hacks/Mods💬 10 posts👁️ 1,389 views
Posted Dec 11, 2009 · 07:08 UTC#1
i was hoping that someone can help me out with some image files. i think i know what files they are but i can't open them. i tried CS3 & Paint but no luck. i was hoping someone would have some files or information that would be helpful in changing the theme of the mod.
BDS_blank.bmp, BDS_trip1.bmp, BDS_trip2.bmp, BDS_trip3.bmp, BDS_trip4.bmp, BDS_trip5.bmp, BDS_trip6.bmp, BDS_tripx.bmp, BDS_gloss_top.bmp, BDS_speedometer_num_mph.bmp, BDS_speedometer_bg.bmp, BDS_speedometer_bg1.bmp, trip_diricon_bg.bmp, BDS_compassmask.bmp
this seems to be all the files that are used with this mod. thanks for any and all help.
Posted Dec 11, 2009 · 07:59 UTC#2
dowbload the image viewer here, http://www.rc-dev.com/i3t/, with it you can open the compressed images and save them as a regular BMP
Posted Dec 11, 2009 · 14:20 UTC#3
thanks for the help with this. program works like a charm and it is free.
Posted Dec 11, 2009 · 14:41 UTC#4
IDT, you are a GODSEND!! I was looking for a program like this without any luck as there are so many bmp's that I couldn't open. Thanks!
Posted Dec 11, 2009 · 15:37 UTC#5
Alex showed me that program last week. Have a question about it though. Once you make the BMP's "regular, edit them, do you then have to switch em back? It IS a major pain not being able to see/open images with PS. :x
dragon, can you tell me exactly the file names of the blue checkered bit in that image are?
Posted Dec 11, 2009 · 16:36 UTC#6
its part of a theme im working on for the unit here. viewtopic.php?f=34&t=29510
here is something i was playing with. old is on the left and new on the right.
Posted Dec 11, 2009 · 16:47 UTC#7
Yea, I know. I just can't figure out which images those are on the top and bottom(with the blue checkered bit). I'd like to edit them but dont cant figure out which ones they are. :?
Posted Dec 11, 2009 · 17:19 UTC#8
you don't have to
Posted Dec 11, 2009 · 17:26 UTC#9
just make a blank image in a photo editer program of 800x480. & load up the 2 files. both file are in the image.res file in the commom folder.
Bottom image is ~ 746_32K_MN-001_24b
Top ~ 746_32K_MN-003_24b
make sure to replace all 4 files if your going to change the button when pushed. the other 2 can be found in the DATA folder in the APL2/iGo/Data.zip. once unziped there are in the ~ ui_pioneer/800_400 folder witht he same name.
If you using the Diaftia's Hybrid mods V2 save the image as AJG_Aurora_iGo.bmp
Posted Dec 11, 2009 · 20:33 UTC#10
i reworked the whole mod and started over on placements of everything. i also fixed the trip computer buton with the right one. your looking for this line in navigatemap_800_480.ui in the iGo data folder.
replace with this line.....
im still working on some coding for this. thanks to the person that took the time to make this mod.
this is the better version with everything all lined up.
