Z110BT freezing
By 1coole60530 · Dec 17, 2009in Problems/Troubleshooting💬 4 posts👁️ 953 views
Posted Dec 17, 2009 · 04:24 UTC#1
Hello all,
Anybody here have problems z110bt freezing, it is happening when using USB drive, I've tired different brands (HP and DaneElec) but daneelec freeze more than the HP. I have another one SanDisk but when it is installed it says that it cannot read the data(sandisk appears not to be compatible)
Thanks in advance.
Posted Dec 17, 2009 · 04:45 UTC#2
Are you using an added USB extension cable?
Posted Dec 18, 2009 · 15:35 UTC#3
No extension cable. Plug in directly to the pioneer supplied cable.
Posted Dec 22, 2009 · 04:18 UTC#4
...check the format of the drives you are using....NTFS...?? try FAT32
