Can u burn a copy of the navi discs?
By bling121 · Nov 30, 2006in General💬 9 posts👁️ 2,184 views
Posted Nov 30, 2006 · 19:33 UTC#1
Just wondering if you can burn copies of the DVD navigation discs??
Posted Dec 01, 2006 · 00:59 UTC#2
Yes you can. It's even legal for you to have 1 backup set of the discs.
Posted Apr 29, 2007 · 02:01 UTC#3
I got a set of DVD+RW tonight, but they aren't big enough to load the whole Nav DVD. Nav DVD is 7GB and the largest DVD+RW I could find are 4.7GB.
What brand DVD+RW are you guys using to make copies? I tried to get a subset (no XM folders) but it is still too much info for the DVD+RW.
Posted Apr 29, 2007 · 02:18 UTC#4
use verbatim dvd-r DL (dual layer). use dvd decrypter to read and write. if you need more info let me know. I'm on here pretty often
Posted Apr 29, 2007 · 02:30 UTC#5
Thanks.
Posted Apr 29, 2007 · 18:07 UTC#6
Looks like DVD Decrypter is not compatible with Vista. I get "UDF File System Parse Error". I tried just moving the files from DVD to DVD+R DL, but I get a read error from the Avic-D3.
Posted Apr 29, 2007 · 22:50 UTC#7
you can try alcohol 120. theres no compatibility settings in vista?
Posted Apr 29, 2007 · 23:37 UTC#8
Just use disk copy in your burner app. You dont have to decrypt the disk to copy.
Posted Apr 30, 2007 · 18:03 UTC#9
I wound up downloading ImgBurn. Worked like a charm.
