On 3 december 2009 Pioneer put their update for f900 and f700 on:
http://www.pioneer-rus.ru/nl/content/su ... 700BT.html
see for yourself.
greetings Rob
see for yourself.
greetings Rob
I wonder why this doesnt include the F90BT. Interesting.
I like that they mention there is a fix to tracklog recording. I am glad that they are aware of it. Hopefully will fix track log recording and trip computers:
Ver. 3.010100
- Stability improvement on iPod alphabetical search.
- Improvement on Track Log recording.
- General UI improvement.
Whats the diff between f90bT and f910BT?
..Bud
Update 3020200 is common for F900/700 and F910/710/9110, F90 not mentioned ?!
F90 -> EU???
No there is no F90 in the EU so why should there be an update from the Pioneers EU web site??
Has anyone tested 3.02 over unofficial 3.0? Any problems? And can the unit still boot to TESTMODE?
Thanks.
AVIC-F500BT Firmware Download and Instructions (-)
This firmware is for AVIC-F500BT which are updated with CNSD-150FM.
* Download the firmware (version 3.020200, size: 312 MB)
Last updated: 3 December 2009
* Download the update instructions
* Download the change history
Thanks.
Hi,
Update (3020200) over IDT´s 3.0 Final- Version with TA 2009.06 Maps >>> System works, no Maps avaible.
I installed then hacked EZrider and Daftias V2.1EU and brand new Maps (2009.09) http://www.filefactory.com/f/a6fc0bef967e8ddb/
IT WORKS FANTASTIC with TMC and BT
Thanks.
Following the automatic procedure described in Pioneer's page is not updated. Should perhaps consider a manual method. Keep in mind that if it does not detect the version 3.0201 (which comes in the CSND-100FM), it may not be updated. The unofficial version we have is 3.0101. Maybe if we change the file versions, work, have not tried it yet.
Ver. 3.010100
I have the official pioneer update and installed 3.00202 without any problems (after backing up all OEM files).
Now I have the latest IDT v2 and 2009.6 TA maps.
Trip computer is not woking!!
Jörg
You are not alone, bro. Mine hasn't worked since I first started adding mods to mine a coupla years now. It has to do with the track logs.
No one has figured it out either. I just have to live with the fact that one of the best aspects of the mods I will just not ever be able to use.
Sorry ![]()
Thanks.
Well, I had to do the update manually, first WinCE upgraded with the new version 6.2.2.8 that comes with the update 3.020200, formatting the flash drive. Then I copy all files in the folders APL APL1, APL2, APL3, TA 2009.09 maps added [091026]. Obviously there are not all the files, I was adding some missing CONTENT folder from the backup I made of the 3.010100 version, copied the ezrider.exe hacked, license files and CommonLib.dll and MainMenu.exe ( changed to 1 millisecond delay) to prevent the screen OK.
Notice, those who want to update manually formatting, backing up the entire flash memory, and then restore folders as DATA, USER, etc. Without those folders will not start the system. I think it best to format, it is overwritten with new files, updating previously WinCE also vary very few files.
The F900BT works perfectly, but I have not noticed changes.
will this update work for US\Canada models? At least upgrade the OS and then use the US\Canada maps? Will that work?
BUMP... I'm interested in this too... WILL IT WORK???
I need to update my unit... I need a fix!!!
Raymond
BUMP
many of us are still wondering if this can be used on USA/Canada?
Tim
I'm running EU 3.02 update on my F500BT. I just replaced the apl folder to upgrade av and bt. It works fine. I couldn't find any major changes other than BT layout (during the call). It displays over right side of screen instead of covering overall screen.
