I searched but I couldn't find anything irrelevant to this exact particular scenario.
I have read that it is possible to install a Avic F500bt INPLACE of a headunit. If you can install it inplace of a headunit, can you hook it up to an aftermarket 4 channel amplifier instead of the ND-G500? Or is it possible to go through and bypass the G500 and then into a different amp? Or would I be stuck with the G500?
Reason being is because the car I wish to install a stereo in, just does not have the room for a deck without severe modification. I was hoping for a bit more power as well then what the ND-G500 can kick out as it will be in a rear engine convertible, so the cockpit is quite loud.
If you can hook it up that way, what would be the disadvantages? I know I wouldn't have radio, but I would just be using my ipod anyways, and I am sure i could stream radio off my iphone into it as well.. Would I be able to fine tune any audio settings what's so ever (like High pass, bass, treble, etc..)?
The compactability of the F500 would be ideal, but I want to be able to control and fine tune the audio settings as well.
