IPOD plays No Sound
By brikkman1 · Dec 22, 2009in Problems/Troubleshooting💬 14 posts👁️ 3,012 views
Posted Dec 22, 2009 · 05:24 UTC#1
So check this out.
I installed my Z110BT and all of the functions are working correctly. UP to today, I have only plugged in the usb to play music, not the IPOD. I tried my dad's 60 IPOD classic and the interfaced changed over from usb to IPOD. Everything seems to be working, but I get no sound. Thinking it could be some setting with the IPOD or something, I tried it with my IPHONE 3g and received the same results.
All other sound inputs work just fine, FM/AM/XM,USB,CD, but it does not seem to work correctly with the IPOD(s). I have the correct cable, came right from the company. Any ideas?
The only mod I've made is the bypass, and that is verified and working correctly.
Posted Dec 22, 2009 · 05:42 UTC#2
Do you have the Pioneer ipod cable?
Posted Dec 22, 2009 · 15:46 UTC#3
yes I do
Posted Dec 22, 2009 · 20:03 UTC#4
Did you change AV Input 1 back to ipod?
Posted Dec 23, 2009 · 05:58 UTC#5
did you connect Aux cable to ipod or iphone audio jack. i got confused too in begining but soon realized what was missing because songs were playing and changing from iphone but no sound.
Posted Dec 23, 2009 · 15:51 UTC#6
did you connect Aux cable to ipod or iphone audio jack. i got confused too in begining but soon realized what was missing because video was playing from iphone but no sound.
No I did not, but I did not think it was required (then again I really haven't read the book either). That would sound extreme old if I had to do that, especially considering I did not have to do that with the z2 ipod adapter. Hmmm, something sounds strange. Hope it isn't flat out broke, I think I threw everything away...... (stupid)
Posted Dec 23, 2009 · 15:52 UTC#7
I believe so...
Posted Dec 23, 2009 · 20:07 UTC#8
Check next time you drive some where
I believe so...
Posted Dec 23, 2009 · 23:33 UTC#9
Yea the previous Z series had a different ipod interface that transferred its audio through the IP-BUS port. The new unit uses USB for control and transfers the AV through the AV1 software input.
Posted Jan 12, 2010 · 07:49 UTC#10
im having the same problem when i installed my unit today.. but i am not using the pioneer optional ipod cable. I am just using the white apple cable that came with my ipod. On the screen it says the songs are playing, but i hear nothing. Do i need to buy the pioneer cable?
Posted Jan 12, 2010 · 08:06 UTC#11
Yes
Posted Jan 13, 2010 · 13:01 UTC#12
If you care about watching video from ipod then yes.
If you just want to listen to music then NO. you need to connect Aux cable between factory cable and ipod aux port.
Posted Jan 19, 2010 · 03:04 UTC#13
I ran into this same problem as well. As stated in the earlier post, you only need the decicated Pioneer Ipod cable if you want to watch videos. For sound alone, you need to connect both the USB cable (for power and control) and Aux cable.
Posted Jan 20, 2010 · 06:08 UTC#14
You need a CD-IU50V, set the AV1 Input to iPod, and there should be no issues. If you have a problem, then you're not doing something right. As stated above, the correct iPod cable, and turning on the input are all that need to be done. USB only will NOT work. USB is only used for charging and control, whereas the 4-ring aux connection is what transmits the audio and video signals.
