1996 4Runner D3, reverse wire question
By terminator2373 · Dec 22, 2009in Hacks/Mods💬 3 posts👁️ 1,537 views
Posted Dec 22, 2009 · 18:02 UTC#1
OK, I've searched and for some reason my 1996 4Runner Ltd. doesn't list the reverse wire the same as other years. It's supposed to be red with yellow strip but all I found behind the cluster are two yellow with red stripe wires. I have the VSS hooked up but can't locate the reverse wire, can anybody help? My dash is torn apart at work and I'd like to get it back together before I leave in a few hours and this one wire is the only thing holding me up. I don't have a backup camera so this may not be necessary to hook up.
Jason
Posted Dec 23, 2009 · 09:23 UTC#2
If you don't have or are not going to get a back up cam then the connection is not necessary.
Posted Dec 31, 2009 · 03:30 UTC#3
If you are going to us a reverse camera, Just tap wire for the reverse lights, and run that all the way up to the radio.You have to have a 25 ft RCA anyway.
