AVIC 9 Upgrade Failure--Need Help
By jl1954 · Dec 23, 2009in General💬 4 posts👁️ 2,058 views
Posted Dec 23, 2009 · 18:21 UTC#1
Need help....Not sure if I'm posting in the right section, but I'm having a problem with my AVIC 9 NavDVD system.
Tried upgrading firmware with DVD disk and midway through the process the system hung/froze. Tried to downgrade back down with original disk and am now getting upgrade error, which prevents the system from working at all. I'm assuming that the newer upgrade disk I tried may've been corrupted. Stepped through most fix procedures I've found online including disconnecting the unit for a couple of days, but nothing seems to work. It's at the point now that the unit is is asking for a password or password code, which I don't have. Pioneer requires sending the unit in for repair for $200.00, plus charges for any work done on the unit. If anyone could assist with this problem I'd really appreciate it.
Roland
Posted Dec 23, 2009 · 20:57 UTC#2
Hi Roland. Sorry to hear about your problem. You might want to try posting in the "General" thread. It seems like there are discussions about the AVIC 9 there, so maybe someone will be able to help.
Other Products/Accessories < General
viewforum.php?f=5
Posted Dec 24, 2009 · 00:48 UTC#3
Thanks and sorry about that......I did post in a couple of different forums because I was not sure which one to post in. Did some searches in some of the forums under AViC 9 but found none. It is a much older unit. I will post in General now.....
Posted Dec 24, 2009 · 01:01 UTC#4
My mistake, I moved it to the wrong forum, sorry.
