| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white & black/red |+ |ignition harness |
| STARTER|red |+ |ignition harness |
| IGNITION|black |+ |ignition harness |
| SECOND IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|blue/red |+ |ignition harness |
| POWER LOCK|blue/orange |- |DKP, 14 pin plug in pin 6 |
| POWER UNLOCK|blue/yellow *1 |- |DKP, 14 pin plug in pin 13 |
| LOCK MOTOR|blue/orange | |DKP, 14 pin plug in pin 2 |
| UNLOCK MOTOR|blue/red | |DKP, 14 pin plug in pin 7 |
| DISARM DEFEAT|blue/red | |DKP, harness to the rear |
| PARKING LIGHTS +|green or grn/red | |headlight switch |
| HEADLIGHTS|red/black |- |headlight switch |
| DOOR TRIGGER|red *2 |- |harness going under dri seat|
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|tied in with doors | | |
|TRNK/HTCH RELEASE|blue |5wi|PKP, harness to the rear |
| TACHOMETER|black | |data link connector *3 |
| SPEED SENSE|purple/white | |ECM behind glove box |
| BRAKE WIRE|green/white |+ |brake pedal switch |
| HORN TRIGGER|green/red |- |steering column |
| WIPERS|blu/org(L),blu/blk(H|+ |steering column |
| LF WINDOW UP/DN|yellow - green |A |driver window switch |
| RF WINDOW UP/DN|grn/org - blu/wht |A |DKP, 13 pin plug |
| LR WINDOW UP/DN|blu/blk - blu/red |A |DKP, 13 pin plug |
| RR WINDOW UP/DN|red/yel - red/blu |A |DKP, 13 pin plug |
| SUN RF OPN/CLOSE|blk/wht - blk/yel |A |at motor in roof |
| SUN ROOF LIMIT|red, green |- |at motor in roof |
| RADIO 12V|blue/yellow |+ |radio |
| RADIO GROUND|brown |- |radio |
| RADIO SWITCH|gray |+ |radio |
| RADIO ILLUMINATE|green |+ |radio |
| LF SPEAKER|pink - purple | |radio |
| RF SPEAKER|lt. green - blue | |radio |
| LR SPEAKER|black - yellow | |radio |
| RR SPEAKER|red - white | |radio |
See if that helps
