Help with wiring in a 2010 Avalon.
By namx · Dec 26, 2009in Problems/Troubleshooting💬 2 posts👁️ 654 views
Posted Dec 26, 2009 · 07:18 UTC#1
I am trying to hook up the z110bt in a 2010 Avalon.
The wiring harness is Scosche TA07SR.
http://www.scosche.com/products/sfID1/151/sfID2/159/productID/1447
The harness has red, orange and yellow wires which I have connected to the power plug of the Z110bt. But it has RCA cables to connect to the LF, LR, RF, and RR channel inputs. Where do I connect these RCA plugs on the Z110bt.
Also, does anyone know where the VSS and the reverse light wires are in the Avalon?
Posted Dec 29, 2009 · 06:44 UTC#2
Ok, your Avalon has a factory amp. Just match the red, orange, and yellow wires. Zip tie all of the other wires on the Avic Harness, because you will not be using them. The RCA inputs from the Scosche harness plug into the Avic RCA harness front and rear output. That's it.
