vss wire and hardware bypass
By woody7795 · Dec 27, 2009in Problems/Troubleshooting💬 7 posts👁️ 1,045 views
Posted Dec 27, 2009 · 18:07 UTC#1
does hooking up the pink speed sensing wire have any effect on the bypassed video working. should i just not use the pink vss wire and not worry about it? thanks
Posted Dec 27, 2009 · 22:31 UTC#2
No, it doesn't, connect the VSS wire.
Posted Dec 28, 2009 · 00:08 UTC#3
Connecting the pink wire to your VSS makes the unit more accurate. And like previously mentioned, it doesn't affect the bypass. What's the make and year is your vehicle ? I'll see if I can't find the location of your VSS wire if you don't know where it is.
Posted Dec 28, 2009 · 18:18 UTC#4
It's a 2007 camry se with a factory non jbl radio. Thanks
Posted Dec 29, 2009 · 00:01 UTC#5
I can't seem to find anything on it, maybe there's someone else out there who might know where it is, will jump in and help.
Posted Dec 29, 2009 · 00:55 UTC#7
thanks for the effort. i really appreciate it. i did a little googling on my own and came up with this. im hoping this is right.
http://commons.wikimedia.org/wiki/File: ... losed.jpeg
Well, that's more than I could find. I'd make sure you have the right wire though before connecting up to it. If I were you I'd go and talk to one of your local stereo installers and they'll usually help you out.
