Transfere contact but not addresses
By [email protected] · Dec 28, 2009in Problems/Troubleshooting💬 8 posts👁️ 2,631 views
Posted Dec 28, 2009 · 23:13 UTC#1
I have the u310bt I am trying to use it with my iphone when I transfer my contacts they transfer to the stereo, when I upload a location to my iphone it goes to contacts as it should. When I go to the car and manually try to upload as the instructions say ,everything transfer except the locations. Any advice would be welcome.
Thanks,
Chuck
Posted Dec 29, 2009 · 08:28 UTC#2
You have to transfer your contacts to the unit again after you have added an AVIC FEEDS location contact to the phone.
Posted Dec 29, 2009 · 15:06 UTC#3
I did that I even entered a false number and name tomake sure it transfered and it did. The location info did not transfer
Chuck
Posted Dec 29, 2009 · 21:22 UTC#4
What do you mean the location info did not transfer? Go to your contacts screen and select the contact with the Pick M next to it, it should take you to the map and prompt you to hit the OK button to plot the route.
Posted Dec 31, 2009 · 17:48 UTC#5
Does this only work with the Iphone contacts or does it work also with windows CE contacts as well?
Kevin
Posted Dec 31, 2009 · 19:04 UTC#6
Hi Chuck. Apologies if I've misunderstood your question, but you have to use the AVIC FEEDS app to upload a location. Unfortunately, you cannot directly sync locations or addresses from your iPhone address book directly to the unit. See the video linked below for detailed instructions.
Pioneer Lab #15: AVIC FEEDS for iPhone
I don't use this feature because I think it easier just to type in the destination.
Hi Kevin. You should be able to sync contacts from any phone with the proper Bluetooth implementation, including almost any recent phone running Windows CE/Mobile. You can only upload locations from an iPhone using the AVIC FEEDS app.
Posted Dec 31, 2009 · 20:59 UTC#7
AVIC-U310BT
Thank you very much for the update, its is too bad they did not update the BT stack to include the other functions, since the unit is running on windows CE 5.0, it would have been a no brainer. I am using the AVIC for the desktop with success. I can only hope they come up with a AVIC update moble version for windows CE for our smart phones.
Posted Apr 06, 2010 · 13:43 UTC#8
These units are not running Windows CE.
