CAN BYPASS BE DONE WITH OTHER HARNESS
By shorty · Dec 30, 2009in Hacks/Mods💬 5 posts👁️ 1,860 views
Posted Dec 30, 2009 · 13:30 UTC#1
Instructions for the bypass use only the RCA Connector Harness (white harness in picture). Is there a way to complete the bypass when you are solely using the alternative black harness? I have the unit connected and functioning well otherwise but not sure if i complete the bypass with this installation. I have grounded the green parking brake lead but have no option to move pin position of a mute wire or other unused option wire. Just cuts off DVD once I go past 5 or 10 mph. Any ideas? (Also lost my steering wheel interface function in the process but may be unrelated)
Posted Dec 30, 2009 · 19:24 UTC#2
You have to use the 2nd harness for the bypass.
Posted Jan 22, 2010 · 04:02 UTC#3
You can add a wire, instead of trying to remove the mute wire. If it cuts off at 5 mph, then the bypass is incorrect. Also, did you install a steering wheel control interface module with the unit, or are you just assuming that they would continue to work with a new radio?
Posted Mar 16, 2010 · 17:37 UTC#4
Is there someone here or on eBay selling just the wire and correct connector to plug into the open slot rather than using the mute wire?
Posted Jul 08, 2010 · 01:39 UTC#5
me =) PM if you still need it
