H1 2000 Hummer where to connect Speed Sensor
By mhawley · Dec 02, 2006in Problems/Troubleshooting💬 4 posts👁️ 1,240 views
Posted Dec 02, 2006 · 00:23 UTC#1
Does anyone know where to connect the speed sensor on an 2000 H1 Hummer . It seems to be to one of the connections on the Digital Ratio Adapter. These are the connections documented in the Service Manual. One person I spoke to said one of the unused pins might have a signal that would work.
Pin 1 not used
Pin 2 not used
pin 3 not used
Pin 4 Cruise Control Reference Signal 4000PPM
Pin 5 Blank
Pin 6 Blank
Pin 7 Vehicle speed Sensor RETURN
Pin 8 Ground
Pin 9 12 Volt ignition Signal
Pin 10 Seedo Reference Signal
Pin 11 Not used
Pin 12 Vehicle speed
Pin 13 Output Shaft Revolution Signal
Pin 14 Not Used
Pin 15 Not used.
I was wondering if I need to connect to one of the wires or if one of the unused pins would have a signal that I could connect to.
Posted Dec 02, 2006 · 03:12 UTC#2
From what you posted, I'd try tapping into pin 10 or pin 4.
Posted Dec 08, 2006 · 19:37 UTC#3
If those don't work, you can tap a yellow wire behind the speedo, not too hard to get to. Tach is also yellow, so make sure you test, test, test.....
Posted Dec 16, 2006 · 23:33 UTC#4
I connected the VSS wire to pin 15 or the DRAC. The pins are not well documented in the HUMMER service manual, but with some help of the Hummer network, I was told that there are several outputs that could be used. So far, this seems to be working well and the 3d mode is also working. I think one could also hook in to pin 14 as well.
