help adding Bluetooth indicator
By gnasr74 · Dec 31, 2009in Hacks/Mods💬 5 posts👁️ 792 views
Posted Dec 31, 2009 · 16:17 UTC#1
Is it possible for someone to post instructions to add Bluetooth indicator I really like it and would like to incorporate it into my mod. Thanks in advance
Posted Dec 31, 2009 · 17:29 UTC#2
Do you mean the one that is included in Diaftias mod in the NAV section to call home? If it is, which NAV mod do you now have? This is really easy to do. I don't want to explain it to you because I don't want you to mess your mod up with the coding, and I have to know which mod it is for as the location will be different
Posted Dec 31, 2009 · 17:34 UTC#3
yes, I am using cmh928's mod with the old interface. I can change the coding myself to locate it on the screen. I just need the right direction and then i can reverse engineer it. i hope. Thanks
Posted Dec 31, 2009 · 22:50 UTC#4
First off, I would reccomend downloading Diaftias mod as it has this already included. Second, Diaftias mod is the most feature rich nav mod out there to date with extras such as call POI's, bluetooth, three dial screens, customizability, just to name a few. CNH928's mod is old and he left everyone hanging as he is not here anymore. I would just ditch it. I cant even suggest how to put it in as there are no more screen shots of his mod that I can find, so I would not even know where to put it. If you wanted to put it in there, just copy the bluetooth bmp to your 800_480 folder and copy the script over to your navigatemap_ui. The trick there is puting it in the location that you want if the default location does not suffice. My opinion though, go with Diaftias V2.1 mod.
Posted Jan 02, 2010 · 15:35 UTC#5
thanks abb1 i wasn't sure if it was simply just changing the nav 800 480 file and adding the bmp. works great just had to adjust the icon placement and runs flawlessly.
thank you
