I just installed the z110 with the bypass and all works well except for a bad speaker connection. Intermittently both right side speakers cut out and put out static and a high pitched noise. I assume it's a loose wire connection but I'm not sure what would cause both speakers to simultaneously screw up. Does that mean that the two left speaker wires are touching each other? Did I screw up the harness when I did the bypass? Thanks in advance for any ideas.
Posted Jan 01, 2010 · 22:00 UTC#1
