What is the purpose of transfering contacts?
By chad711 · Jan 02, 2010in General💬 8 posts👁️ 1,464 views
Posted Jan 02, 2010 · 23:34 UTC#1
I see this option on the z and I read the instructions on it but I do not understand why you would do this? Every time I get in my car the contacts transfer via bluetooth as soon as phone is found.
Posted Jan 03, 2010 · 00:12 UTC#2
Actually that is a good question. It does prove useful when your BT connects before you hit the OK button on the map screen. That causes the BT calling feature to fail. If this happens you can use the transfer contacts feature to fix the problem. Also, if you use the AVIC FEEDS iPhone app while your unit is running, you can use the transfer feature to get the new GPS contact to blot your route from.
Posted Jan 03, 2010 · 04:44 UTC#3
That makes sense. So if I do not hit the OK button on the NAV before the BT connects it will fail? There has been times where I didn't use the NAV and so I never hit the OK button but my contacts loaded and was able to make calls. Is this different then what you are saying?
There is also a AVIC FEEDS icon on the unit but it's always greyed out. I have a iphone and the avicfeeds app so do these two have anything to do with each other?
Posted Jan 03, 2010 · 05:16 UTC#4
The contacts will transfer but the VR will fail for calling if the BT connects before you hit the OK button on the map screen. This is only a concern if you use the VR to make calls. The AVIC FEEDS icon on the unit i for accessing POI on SD card created with the AVIC FEEDS PC app.
Posted Jan 03, 2010 · 08:33 UTC#5
Adn what is VR? I see this once and awhile when I connect my iphone for listening to music. Something about updating VR Library or something.
Posted Jan 03, 2010 · 08:36 UTC#6
Its only the most advanced feature on the unit.
Posted Jan 03, 2010 · 19:18 UTC#7
LOL, that didn't answer my question...
Posted Jan 04, 2010 · 02:34 UTC#8
VR = Voice Recognition
