Power to F500BT cradle without big cable
By Scotto · Jan 04, 2010in General💬 4 posts👁️ 982 views
Posted Jan 04, 2010 · 21:17 UTC#1
I would like to find a way to power the cradle for my F500BT with out using the big fat cable which comes with the cradle. In my case, I have a full installation in my car with the ND-500G amp. It works great, but I would also like to be able to occasionally use the unit with working MSN Direct in other cars, such as a rental. To get the MSN Direct to work, I believe that the cradle needs to be powered directly.
It is possible to buy a second cable from Pioneer for about $45, and come up with way to use it with a cigarette lighter plug. However, there are two problems with that: 1) I am cheap, and 2) that is a big ugly cable to drag around when I do not need any of the other connections for the cable. Is there some simple, cleaner way of doing this?
Posted Jan 05, 2010 · 14:15 UTC#2
m2, wish there is a shorter cable with just the cigarette adapter and stereo jack (TRS).
Posted Jan 20, 2010 · 11:21 UTC#3
Mine came with the large cable, cigarette lighter adapter and an ac power supply. I use the cigaretter lighter adapter to use in other vehicles.
Posted Jan 23, 2010 · 01:01 UTC#4
The problem is that the MSN Direct receiver is in the cradle, and the bundled cigarette lighter adapter powers only the F500BT but not the cradle. As a result, MSN Direct can not be used with this adapter. Some other way to provide power directly to the cradle must be devised.
