Do you need a wire for your bypass?
By jernelson · Jan 06, 2010in Hacks/Mods💬 5 posts👁️ 1,936 views
Posted Jan 06, 2010 · 03:06 UTC#1
A wire off an idatalink bypass module used for remote starters plugs right into the Pioneer harness. You can remove the wire by simply lifting a little tab on the outside of the plug and pull the wire right out. I use these modules daily and throw about 20 of these wires away everyday. Any car stereo shop that does car starters may use this brand also and should be able to hook you up with a wire.
Posted Jan 22, 2010 · 04:00 UTC#2
Strip 3" off the end of a piece of standard 18 ga, cut off all but about 8 strands, and twist them very tightly. Push them through the hole on the connector where it's needed, and pull it so the rubber jacket wedges inside the connector (hence the need for 18ga, need a large enough jacket). Cut off the excess, leave ~1/16th". Bend the remaining copper up and away from any other pins. Ground the new wire, no pin needed, completely reversible mod, and leaves the mute wire in place.
Posted Mar 07, 2010 · 21:52 UTC#3
jernelson- do you have an extra wire you could mail me? i could really use it. thanks!
Posted Mar 18, 2010 · 19:14 UTC#5
just got my z and this worked for me, after fiddling with moving the mute i tried this.
it worked great, although i only needed 3-4 copper strands in my 18ga.
thanks alot
