D3 and ACA200W(cam) black screen
By stang5_0 · Jan 07, 2010in Problems/Troubleshooting💬 11 posts👁️ 1,446 views
Posted Jan 07, 2010 · 08:14 UTC#1
Greetings.
I have searched high and low using every possible combination of search terms and no dice.
2007 H3
HU AVIC D3
CDBTB200 Paired perfectly with my Blackberry Curve and Axim X51
GEX-P920XM XM Satellite Tuner - Working
Bypassed
Tonight I installed the license plate cam and wound up with a black screen when using the camera.
It switches when I go in reverse, test from bottom to top or whatever it is.
And this is how I wired it:
From the ACA200W
RCA-HU
Black to ground
Red to reverse light
And the purple and white wire goes from the Avic to the same reverse light.
When I start up, I get some horizontal lines. Not an issue at this point since I don't even have a picture.
So did I totally screw things up here or what? I guess I was confused about the purple and white wire and what purpose it server. If both that and the red pos from the cam can goto the reverse light, great. I hope I've provided enough information, but please let me know if you need any other info.
But that's where I stand. I have yet to test with another video source, but that's next.
Thoughts guys?
Thanks,
Stang
http://www.stangsgarage.com
Posted Jan 07, 2010 · 09:41 UTC#2
Go into the setting and turn the camera on.
Posted Jan 07, 2010 · 14:53 UTC#3
That was the first thing I did after the install.
I am going to recheck the power lead just to be sure later today, but I'm pretty sure it's hot.
I wish it were that easy.. :cry:
Posted Jan 07, 2010 · 21:09 UTC#4
This is your problem. The red wire should be connected to the red wire from the head unit. Otherwise the camera has no power when trying to use rear view.
Posted Jan 07, 2010 · 22:01 UTC#5
Wow, it's that easy?
Not really enthused about running yet another wire that distance, but hey, if that does the trick at least I can put it behind me.
Ya know it's funny though, I never once saw any kind of mention about this.
Now is this a particular red wire, is it labeled, or do I look for the power lead for the stereo? The D3 was in the truck when I bought it, I added all the rest.
If this is the ticket though I shall certainly report back.
I think to check though, I'll just run something to the back and see if it works before running another lead. I like everything to be very well hidden, and I even managed to pass the wires from interior to exterior without a drill or any visibility. Trouble is, that takes time.
To save even more time in testing that, what about this idea? In the back there is a power source. I have a plug I keep handy with bare wires for testing. I could just test for power like that unless you think I'll hose something in the process? After all, I also know haste makes waste. ;)
Thanks for the reply,
Stang
Posted Jan 07, 2010 · 22:10 UTC#6
You need to take the red 12v+ wire from the camera and tap it into the red switched 12v+ wire of the head unit. Do that and your problem goes away.
Posted Jan 07, 2010 · 22:26 UTC#7
You have no idea how long the next 2.5 hours will be now. That's how long I have to wait before I'll be home to try this.
Thanks again, and I'll let you know what happens.
Stang
Posted Jan 08, 2010 · 05:14 UTC#8
Hiya VBLUE
I am happy to report that did the trick. Thank you so much, I can't believe how simple it was. Not sure why it wasn't in the documentation or in forums, but it worked.
Here are a couple pics for what it's worth.
Went with the location above the plate. Seems to be plenty enough light still lighting up the plate. Used the special bolts provided, nice touch.
Finished up the install and took a picture of my view. Thanks again VBLUE! :D
Stang
Posted Jan 08, 2010 · 05:24 UTC#9
Glad I could help. :D
Posted Jan 30, 2010 · 18:44 UTC#10
I have the same camera and have had it working for a while... but now the image comes on sometimes and not others... I assumed it was a bad ground or hot... no luck with that... Anyone have problems with this camera... I have had it for about 1.5 years and there were no impacts, accidents, or mods to the camera or wiring. Thanks if anyone has any suggestions. I hooked the composit wire to my sony video camera and it displayed on the radio.
Posted Jan 30, 2010 · 18:51 UTC#11
The camera has probably reached its end of life. This camera is a CMOS camera and in my experience those usually don't last very long. In contrast, the BOYO VTL400 CCD camera I have has been going strong for almost three years now.
