fm reception
By woody7795 · Jan 07, 2010in Problems/Troubleshooting💬 8 posts👁️ 2,311 views
Posted Jan 07, 2010 · 21:49 UTC#1
ive got my f90bt in and the thing is awesome but the stations i always used to listen to now come in like crap. i checked the antenna it's good. ive gone in and turned the "local" on and it helped. i don't know what else to do. anyone else have this problem?
Posted Jan 08, 2010 · 16:25 UTC#2
That's been the problem with every Pioneer i've ever owned. I use a signal booster on mine. that helps too.
Posted Jan 10, 2010 · 03:43 UTC#3
Woody, I had the same prob after my install. I fixed it by connecting the FM antenna power cable to an existing cable in my car, I'm going to look at the wiring diagram and see if I can remember what exactly I did, sorry I don't have an answer at this time. But I do remember it made a huge difference.
Posted Jan 10, 2010 · 06:04 UTC#4
Hope this helps, I had poor reception until I connected the blue wire from the Avic unit- auto antenna relay control terminal to my antenna booster power control terminal on my car (refer to your vehicle wiring diagram), I have a Mercedes with a rear glass antenna. If you have an in glass antenna, I know you need to do this, otherwise if there is any power from your old antenna, connect it there. Perhaps pull the unit out and experiment/trouble shoot. My unit works flawlessly now, but I've pulled it out approx. 4-5 times fixing small probs, the latest being the RCA connects on the Ipod connection, but that's another thread. Good Luck!
Posted Jan 11, 2010 · 18:41 UTC#5
It was the blue wire. I didn't think I needed it when I installed it. Now it works great. Thanks everyone
Posted Jan 13, 2010 · 01:17 UTC#6
Does anyone know where to connect this blue wire to in a 08 cobalt. My FM reception is ok at best. Im also using the GMOS Lan adapter so I could keep all the onstar stuff and there is nowhere on the adapter to hook up this wire. Thanks
Posted Aug 28, 2012 · 13:28 UTC#7
OK, same problem with my f90bt, poor FM signal, favorite station fades in and out to quietness no static,at a light i just have to move forward a foot or two to listen. AM = mostly static. Antenna is outside rt front fender mast type and plugged in with no antenna booster, not sure if blue wire is connected. Would a new antenna and/or booster make a difference?
Posted Aug 31, 2012 · 20:41 UTC#8
This issue arises in many cars because, unbeknownst to the owner, there is an antenna amplifier in line with your antenna that needs power to make it work. My 2005 Subaru WRX was like this. I didn't realize that a pin in the harness actually supplied this power. I never knew there was an amp. It's particularly common on cars with in glass antennae.
