reboot is still an issue even after....
By jordan7526 · Jan 08, 2010in Problems/Troubleshooting💬 5 posts👁️ 713 views
Posted Jan 08, 2010 · 20:57 UTC#1
I was able to boot into test mode, delete the 4 files necassary...and restart the module....for some reason its still giving me the same exact problem..any incite would be appreciated..
thanks,
jordan
Posted Jan 08, 2010 · 21:43 UTC#2
When you open your SD card on your PC, what do you see from the top level? Do you see are directory called testmode or a bunch of files? You need to see a directory called testmode and that's it...
Posted Jan 08, 2010 · 21:45 UTC#3
yeah all it says it testmode, when i turn the car on , it doesnt recognize the sd...this is an 8gb card with nothign but test mode on it....i have the 2.0 system currently...any ideas?
Posted Jan 08, 2010 · 23:02 UTC#4
You might want to format you SD card. Make sure you do it as FAT32 or FAT16 format. Then try re-writing the /testmode directory to it and try again,,,
Good luck!
Posted Jan 08, 2010 · 23:37 UTC#5
yeah...its a 32 :/ i am operating on windows 7 would that make a difference?
