Front Auxiliary input
By built2hurt · Jan 11, 2010in Problems/Troubleshooting💬 15 posts👁️ 9,076 views
Posted Jan 11, 2010 · 19:53 UTC#1
Is there something i need to do in order to use this auxiliary input? I have an F90BT and an older ipod that i'm just trying to go from headphone jack to the aux input on the front but i'm not having any luck. any help is greatly appreciated.
Posted Jan 11, 2010 · 23:56 UTC#2
Its in the manual.
Posted Jan 12, 2010 · 14:54 UTC#3
Go to settings -> Audio Settings. Click on the 2nd button for AV2 until it says "video". Now it is activated. Next, choose your source as AV2, (on the bottom), and that's it.
Posted Jan 12, 2010 · 15:07 UTC#4
I have read through the install manual. It seems that you have to use the "CD-RM10" cable from pioneer to get the front input to work. Is that the case? I do not want to buy this cable unless I need to.
Greg
Posted Jan 12, 2010 · 18:12 UTC#5
Either that cable or one with the same connections is what you will need.
Posted Mar 11, 2010 · 15:26 UTC#6
I've tried this a few times so far.
On my deck I have the iPod cable that has to be connected in the back through the USB and the RGB cables (the red, white and yellow). When I put it in video mode, it doesn't read my AUX cable. I'm thinking it might be the fact that it's trying to read the iPod??
I've got a Blackberry Storm2 with Pandora, and I like to listen to that sometimes but it won't let me... kind of a letdown.
On another note: I have to disconnect my iPod and reconnect it EVERY time I turn off my car. It won't recognise the iPod immediately. I'm thinking it might be an underlying reason why my AUX port is being a douche. That and occasionally my bluetooth will just go really soft and I can't hear the person talking, as well as it often doesn't connect fast enough to end a call then call someone else without just letting it chill. The music takes a long time to get back on.
I still find it hard to accept that I have to hack and modify this deck like there's no tomorrow just to get it working right and the way you want it to. They had a great product but didn't execute it properly, and still to this day! Gotta get some 3.0 on there and see if it makes a difference. I'm hoping it'll fix my iPod woes...
CF: iPod is connected with AV+USB, AUX won't work. BT messes up as well + random rant.
Posted Mar 11, 2010 · 15:35 UTC#7
Ok what your righting does make clear your problem. What aux cable are you referring to that is affecting the iPod cable? No other cable should affect the iPod cable. Try again and be a little more specific on what your actually trying to do.
Posted Mar 11, 2010 · 15:43 UTC#8
I'm trying to run my Blackberry through the front aux cable on an F700BT. I'm using a auxiliary-to-auxiliary cable. I also have my iPod plugged into the back using a USB-AV cable.
When I change the setting to AV2 it doesn't run the sound from the front aux, it just does nothing.
Posted Mar 11, 2010 · 15:59 UTC#9
What setting are you switching AV2 to?
Posted Mar 11, 2010 · 16:02 UTC#10
I've tried all the combinations. Nothing seems to work. One of them plays the iPod and all the others don't do anything.
Posted Mar 11, 2010 · 16:14 UTC#11
Just tested it with my Droid.
Connected the two devices, went to AV setting and set AV2 to video,
then went to AV source and selected AV2 tab at the bottom.
I do have an iPod connected as well and that did not affect it.
Posted Mar 11, 2010 · 16:34 UTC#12
The iPod should be a on AV1 so that has nothing to do with AV2. Why do you keep talking about the iPod? Your still not making any sense.
Posted Mar 11, 2010 · 17:04 UTC#13
It's just the only thing that I think could be affecting it(the iPod I mean).
I've tried all the inputs a while ago, put I'll try it again later when I get in the car.
Posted Mar 11, 2010 · 17:13 UTC#14
Yea AV1 has no affect on AV2. Your issue is with AV2 alone.
Posted Mar 12, 2010 · 13:06 UTC#15
Sweet, I got it working. Thanks guys.
