Can't access my top menu in testmode/CE
By nhlman · Jan 11, 2010in Hacks/Mods💬 2 posts👁️ 639 views
Posted Jan 11, 2010 · 23:14 UTC#1
When I get into CE, no matter how hard I try or what kind of stylus device I use, I cannot click on anything in the top menu pane (File, Edit, etc). In order to install the 3.0 mod, I had to use the drop and drag technique. I now want to do Diaftia's mod and I can't delete the files at the end of the guide because I can't access the delete command from the top menu, any suggestions?. BTW, everything else in CE is clickable.
Posted Jan 11, 2010 · 23:43 UTC#2
Calibrate your screen.
