need to know the color of speed sensor wires
By clk320 · Jan 12, 2010in Problems/Troubleshooting💬 4 posts👁️ 944 views
Posted Jan 12, 2010 · 06:31 UTC#1
Hi having problems with the speed sensor on my avic z1 it's reading 0mph i didn't do the install on my avic z1 some shop did it. and i think they didn't hook it up right i have a clk320 98 any help is appreciated thank you
Posted Jan 20, 2010 · 16:17 UTC#2
I show that the 1998 C-Class VSS wire is located at the radio harness:
VSS Wire: Green/White Or Green/Black or Green/Yellow at Radio Harness
Posted Jan 21, 2010 · 06:52 UTC#3
garrey thanks but can you tell me to which cable on the avic z1 should i connect the vss i really mean what is the color cable that i should connect my vss from to the avic z1.
Posted Jan 21, 2010 · 12:41 UTC#4
Ah, that's easy. It's the Pink wire in the same harness as the power and ground wires.
