I just received my Z110BT and about to do the bypass, but I am bit confused on the removing the pin part. This one is trickier than the F series one I did. I followed the instructions on the bypass, but I cannot get the pin to release and fear I am doing it wrong. I don't want to damage my harness.
So what is the trick to removing them? I put a pin in the bottom hole (two very small holes are visible on each row on the plug in side) and I feel like I am just destroying the plug. Is this right?
Mod Edit 01-14-2010:For those of you that are having a hard time removing the mute wire from the harness this should help. Courtesy of Soundman Car Audio.
