910bt problem
By d1same · Jan 15, 2010in General💬 8 posts👁️ 3,404 views
Posted Jan 15, 2010 · 19:39 UTC#1
Hello,
I recently upgraded from AVIC-U310BT to AVIC-X910bt. I didn't replace the power wiring with the old one I had, because when I checked, everything looks the same. I plugged in everything. The navigation,ipod, radio work great. but when I go to the phone every icon is faded out and I won't be able to choose the setting or anything. I have the same problem with system setting icon. What could be the problem?
Posted Jan 15, 2010 · 21:31 UTC#2
Fixed!
I changed the wire and connected the light green wire strait to the parking brake electricity so I don't have to push the break to get it to work. I just hope it wouldn't effect anything.
Posted Jan 16, 2010 · 00:21 UTC#3
Unless the parking brake wire is properly connected to the parking brake wire as detailed in the installation instructions requiring the P brake to be pulled to use the lock out functions or the bypass is performed as instructed on this site, you will get locked out soon.
Posted Jan 16, 2010 · 05:01 UTC#4
The installation says to connect it to the green wire. but the thing is when I connect it to the green wire my phone and address won't work (it stays gray) even if the car is not moving. unless I push down the parking break. but when I connect it to the brown wire everything work fine. (when the car moves I can't use dvd player, phone, address. but when the car stops everything comes back to work, which I know I have to do the bypass)
I'm a little confused.
Posted Jan 16, 2010 · 05:14 UTC#5
The installation instructions for the P. brake says you have to pull the P. brake to access the features. You clearly have not followed the directions and may be causing damage to your unit. Either follow the install directions for the P. brake hook up or follow the directions here for the Bypass. What ever you do, do it right before you screw up your unit.
Posted Jan 16, 2010 · 18:26 UTC#6
Just to make sure.
If I do the bypass I don't have to connect the green wire to the P-Brake anymore right? I just ground the mute and green wire. right?
Posted Jan 16, 2010 · 18:31 UTC#7
Yes, that is correct. Follow those instructions as described and you will no longer be locked out or have to engage you parking brake.
Posted Jan 16, 2010 · 18:59 UTC#8
Alrighty. Thank you.
