ip-bus bt and cd changer?
By lilgerber · Jan 19, 2010in General💬 4 posts👁️ 1,295 views
Posted Jan 19, 2010 · 19:18 UTC#1
Okay i have a BT mod right now hooked up, and just bought a 6 cd changer .The problem is they both require the ip-bus cable port, and their is only one port on the back of the D3 unit.
Ive search for a ip-bus splitter but no luck. Is their such a thing,and what are you guys doing? How can i have both running?
thank you ,
Aaron
Posted Jan 19, 2010 · 22:04 UTC#2
Did you even look at the BT module?
Posted Jan 21, 2010 · 04:59 UTC#3
is their another port on it? ill go check out out right now,
i just pulled out the unit and saw the port is in use, and the Bt mod is tuck far away.
Posted Jan 21, 2010 · 05:16 UTC#4
There is another port on the BT module.
