blue tooth
By bob_1980 · Jan 21, 2010in General💬 10 posts👁️ 1,416 views
Posted Jan 21, 2010 · 05:52 UTC#1
does anybody know if I can hook up a external bluetooth adapter and use it instead of the built in one
the bluetooth in this thig blows. after spending $2000 on a head unit i expected it to work
Posted Jan 21, 2010 · 05:56 UTC#2
Why don't you let us know what problems your having? The BT works great for me.
Posted Jan 21, 2010 · 06:01 UTC#3
im finding that when people are talking to me it is very broken up
and people say the echo is very bad when i talk to them
Posted Jan 21, 2010 · 06:36 UTC#4
That doesn't sound like an issue with the BT to me as apposed to a phone issue. Have you tried your unit with a different phone? Also, do you have the echo cancel setting turned on?
Posted Jan 22, 2010 · 04:26 UTC#5
If you have the echo cancellation in the unit turned on, try checking your phone for an echo cancellation system, as well. If your phone has it, turn it off. Also, what vehicle, and where is your mic located?
Posted Jan 22, 2010 · 05:31 UTC#6
hi I have the mic on the steering colum about 12 inches in front of me
i have a iphone 3g . it worked perfectly with my previous D3 . it is installed in a 2004 dodge ram.
im also having problems hearing people very broken up.
Posted Jan 22, 2010 · 05:36 UTC#7
Try a different phone and see if you get the same result.
Posted Jan 22, 2010 · 07:41 UTC#8
Did you swap out the microphone when you installed the deck, or did you use the one from the old CDBTB200? Some people have reported better results with the one that comes with the deck
Posted Jan 22, 2010 · 15:33 UTC#9
i used the one that came with the 110
Posted Jan 22, 2010 · 15:33 UTC#10
im going to try another phone as soon as i can
